Configure what application TACACS+ authenticates: CLI, web, or all.
TACACS+ authentication provides control of authentication through login and password.
By default, CLI authentication is enabled.
- You must enable TACACS+ globally for TACACS+ authentication to function.
Configure TACACS+ to authenticate CLI and display the configuration.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#tacacs authentication cli Switch:1(config)#show tacacs Global Status: global enable : true authentication enabled for : cli accounting enabled for : none Server: create : Prio Status Key Port IP address Timeout SingleSource Source Enabled Primary Conn ****** 49 192.0.2.1 10 false 0.0.0.0 false Backup NotConn ****** 49 198.51.100.2 10 false 0.0.0.0 false
The following table defines parameters for the tacacs authentication command.
| Variable | Value |
| all | Specifies TACACS+ authentication for all applications. By default, CLI authentication is enabled. |
| cli | Specifies TACACS+ authentication for command line connections. By default, CLI authentication is enabled. |
| web | Specifies TACACS+ authentication for web connections. By default, CLI authentication is enabled. |
